- Concurrent Views: Displays how many viewers are watching the stream at each second. As viewers join and leave the stream, this number will fluctuate up and down.
- Total Viewers: Shows how many viewers have watched the stream since the current broadcast began. if you stop and restart your broadcast, this number will return to zero. Reconnecting within two minutes will keep the total number intact. This number is cumulative so you will never see a downward trend. This number is not unique viewers. If a viewer watches the stream for a while, leaves and comes back, that same viewer can be counted twice in the total viewer number.
